NTP Problem
connorm
here is the issue im having
Running in Router mode but as an AP
once i setup the script to run at every boot i can connect to the router over the internet
initially i noticed NTP wasnt working, but i figured once the default gateway was entered the issue would be fixed, however it is not...
im using ca.pool.ntp.org as my ntp server
this message keeps popping up in my logs
notice how the time on the logs is wrong haha, almost every reboot the router just picks a random time to start from lol
Aug 4 09:25:12 hour monitor: ntp is not syn
Aug 4 09:25:42 hour monitor: daemon is starting
Aug 4 09:25:42 hour monitor: ntp is not syn
Aug 4 09:26:12 hour monitor: daemon is starting
Aug 4 09:26:12 hour monitor: ntp is not syn
Aug 4 09:26:42 hour monitor: daemon is starting
Aug 4 09:26:42 hour monitor: ntp is not syn
Aug 4 09:27:13 hour monitor: daemon is starting
Aug 4 09:27:13 hour monitor: ntp is not syn
Aug 4 09:27:42 hour monitor: daemon is starting
Aug 4 09:27:42 hour monitor: ntp is not syn
Aug 4 09:28:12 hour monitor: daemon is starting
Aug 4 09:28:12 hour monitor: ntp is not syn
Aug 4 09:28:42 hour monitor: daemon is starting
Aug 4 09:28:42 hour monitor: ntp is not syn
Aug 4 09:29:12 hour monitor: daemon is starting
Aug 4 09:29:12 hour monitor: ntp is not syn
Aug 4 09:29:42 hour monitor: daemon is starting
Aug 4 09:29:42 hour monitor: ntp is not syn
this was also appearing in the logs around the time of boot
Jul 31 17:04:42 kernel: TCP: time wait bucket table overflow
would be nice to get NTP going
still didnt work.....
and yeah i thought of the IP instead of regular address doesnt work, the router cant even ping out to 8.8.8.8
No pretty sure not where can i double check?
well, i added manual route so 0.0.0.0 all goes to 192.168.1.1
now i can ping google etc, i can ping the ntp server, however NTP is still not working...
So now that i got that working im noticing this happening in my logs starting right after i fixed this around 8:30 my time (pst) last night
smbd[6931]: [2016/01/12 20:42:56.460278, 0] ../libcli/auth/ntlm_check.c:54(smb_pwd_check_ntlmv1)
Jan 12 20:42:56 smbd[6931]: smb_pwd_check_ntlmv1: incorrect password length (74)
Jan 12 20:42:56 smbd[6931]: [2016/01/12 20:42:56.485492, 0] ../libcli/auth/ntlm_check.c:54(smb_pwd_check_ntlmv1)
Jan 12 21:00:18 disk_monitor: Got SIGALRM...
@RMerlin you might wanna fix this as it is very easy to fix and clearly stemming from merlin-wrt/asus-wrt
