2. It doesn't.Researching the various options for a new wireless router, the Asus AiProtection feature got my attention. I´d appreciate input from Asus users regarding the following questions:
1. Does AiProtection work flawlessly?
2. How much does AiProtection degrade the speed?
I know. i was just checking to see if the issue shad been resolved, since others reported that webroot was not a problem. So far so good. no lockups in 24 hours.@bradbort : If you enable anti-virus of PC and you find something abnormal, suggestion you to disable Vulnerability Protection of AiPotection.
In general, AiProtection seems to work, but it has issues.
One of the major problems with AiProtection (all firmware versions) is that it blocks FTP client traffic, specifically ACK packet traffic from the FTP client to the remote (outside of network) server.
When "AiProtection - Vulnerability Protection" is enabled, ACK packets are blocked at the router, This has been a problem since the RT-AC3200 release, and none of the firmware upgrades have corrected it. I have verified the issue using Wireshark and other tools. If "Vulnerability Protection" is disabled, everything works fine.
NOTES:
- Current (junk) firmware version 3.0.0.4.378_7838 in use that works best with a variety of other flaws.
- It does not matter which FTP client is used.
- No problems using other routers or when Vulnerability Protection is disabled
- Verified using Wireshark, ACK packets blocked
- Server is NOT within network, in fact it is all the way across the country
Negative.
Use of the FTP port 21 forward is unrelated. As I stated, this is ONLY related to AiProtection >>> Vulnerability Protection. As I also stated, the server I must regularly connet to is NOT within the network (i.e. behind the router). The PC FTP client is behind the router, within the network. Trying to connect to any point outside the network fails because ACK packets are blocked at the router.
Unfortunately, your response exemplifies one of the biggest issues with ASUS Support --- where clear comments do not seem to be read or undrestood. If the issues had anything to do with port 21 I would have stated so.
I've been hoping for over a year to receive functional fully firmware, and after monitoring this site for months I decide to make a post and receive a similar response to the dozens I've received by email. An extremely frustrating process.
Hi Sam,Thanks JK:
Would you prefer individual threads related to specific issues, or a general post that includes them all (but might get messy with responses)?
Hello Vanic, can you make a build for the RT-AC68U? Or do one of the two you have in the dropbox, would work for my route model? I was having the same issue as Sam. AiProtection->Vulnerability Protection had to be disabled for ftpes (TLS) to work.Hi Sam,
Could you try this beta firmware here?
http://www.snbforums.com/threads/be...king-bug-in-traffic-analyzer-statistic.28098/
I should be fixed this issue for a long time, this firmware is too old. If you still encounter issue again, you can contact with me directly via smallnetbuilder conversation or send mail to router_feedback@asus.com, please add title [AiProtection for Vanic], hope I can help you!
Thanks,
Vanic
Thread starter | Title | Forum | Replies | Date |
A | Run custom script on official ASUS firmware | ASUSWRT - Official | 10 | |
Testing connection with iperf3 on official AsusWRT | ASUSWRT - Official | 4 | |
E | Merlin strings in the LOGs with ASUS-WRT official fw | ASUSWRT - Official | 8 |
Welcome To SNBForums
