OpenVPN Client by policy rules help
BeachBum
I am running Merlin 380.57 and have the Open VPN Client connected and running. I want to set it up so that only certain devices on my network are running through the VPN, not everything on the network.
I get the Source IP, but what it the "Destination IP" field for in the rules list?
Please see the firmware's documentation. There's a section in the README explaining the fields and giving various examples.
Ah I see it now. Thanks Ill git it a shot and see how it goes...
I route all traffic and then add exceptions with the following rules:
Description Source IP Destination IP Iface
all 192.168.1.1/24 0.0.0.0 VPN
games1 192.168.1.180 0.0.0.0 WAN
games2 192.168.1.181 0.0.0.0 WAN
appletv 192.168.1.182 0.0.0.0 WAN
You can see there I've specified games1, games2 and appletv to use WAN (bypass the VPN).
However I would love to know if there's a way to specify an address range in one line.
For example above, how I would specify all addresses in range 192.168.1.180-192.168.1.190 to go through WAN, instead of needing to specify them individually? Perhaps not possible?
Not possible, unless you were subnetting. The IP must be entered in CIDR format if you want to specify a range.
Whilst the GUI doesn't allow it, technically you can use a script.
NOTE: RMerlin does not advocate the use of fwmarks (although both ASUS and RMerlin's code use them :p)
#!/bin/sh
for i in /proc/sys/net/ipv4/conf/*/rp_filter ; do
  echo 0 > $i
done
TAG_MARK=128
RPDB_TABLE=254          # 254=WAN,11x=VPNx  (NOTE: 380.58+ will allow 100=wan0,111=ovpnc1,112=ovpnc2 etc.)
IP_RANGE="192.168.1.180-192.168.1.190"
ip rule add fwmark $TAG_MARK lookup $RPDB_TABLE prio 999
ip route flush cache
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range $IP_RANGE -j MARK --set-mark $TAG_MARK
although the RPDB rule will not be visible in the GUI! ...however, you can always create a 'dummy' entry via the GUI to 'remind' you to check the external script! ;)
Or, you can use a range to CIDR calculator :)
http://www.ipaddressguide.com/cidr
IP Range to CIDR
This tool converts IP range to CIDR.
CIDR, 192.168.1.180-192.168.1.190:
192.168.1.180/30
192.168.1.184/30
192.168.1.188/31
192.168.1.190/32
appletv 192.168.1.182 0.0.0.0 WAN...
This is a better way to do it actually, I've set it up like this and so far it seems to be running well..
