Openvpn dns setting
CrazyCanuck
Openvpn will use vpn provider dns server although it is disabled with accept DNS configuration from the VPN server. I had to down grade from 380.65.4 to 380.65.0.
My router is ASUS RT AC 56 U.
Absolutely zero change to the code related to either DNS or OpenVPN between these two versions.
44495cc Updated documentation
5606a54 Bumped revision to 380.65_4
7eb0e49 rc: re-enable code that causes some router models to reboot if one of the radios is disabled at boot time, and set limit it to 1 reboot instead of 3 like it originally did (compromise for issue #1284)
9cb6819 Updated documentation
b847f95 Bumped revision to 380.65_3
f267e2d Updated documentation
0407856 shared: explicitely check for gmac3 being enabled when retrieving wan/lan MAC, rather than checking if it's not force-stopped.
92e53c8 rc: initialize gmac3 nvram as disabled on SDK 7.x, else code portions specific to SDK 7.x might break - for instance, it broke various things with the RT-AC3200.
6b41620 Fixed typo in documentation
aa65182 Bumped revision to 380.65_2
22125e0 Updated documentation
93b2c09 webui: fix broken WOL page if client name contains single quotes
513ad7e webui: escape quotes in client names when building clickable client list, fixes DHCP page (and possibly others)
773e8cc networkmap: backport 7266 code, includes buffer overrun fixes
823d4a0 httpd: temporary patch to protect against CVE-2017-6549 (while we wait for a proper fix from Asus)
