OPENVPN over ISP modem?
bayern1975
hello, i can't get openvpn working if the ISP modem create pppoe connection. my asus is behind ISP modem and set to automatic IP...is there any solution to get working or is not possible with this combination?
sent from Kodi 17 Krypton
i have a static ip address so i think i do not need ddns active...but this is not a big problem....i need information how to connect to openvpn over isp modem....my isp modem have IP 192.168.1.1 my asus have 192.168.2.1...which port use openvpn to comunicate with network?
I'm talking about your public IP address. Not your Local. Two separate things.
OpenVPN is built into the software under VPN. Do as I said above first.
Yes i know you are talking about public address and my is static...it is same all the time....
