It's not such a big problem for me, it's about to add 2 rows to the config on a server side. But it's a bit strange to hear that it's not the default as a reason for backwards compatibility. Until previous version if there was no topology row in server setup it supposed net30 as a default and all clients the same. Now, when I change a server to the latest version (without change of config), all the clients still suppose they use net30 (until I've upgrade them too) and reject to connect. I don't thing we can talk about backwards compatibility even if it can be achieved easily. It was a change of some default settings and as such should be mentioned at least in the changelog. Otherwise it's difficult to find it from server side because it can be seen only in logs on client side, you know. That's my point of view.
