I had this working some versions ago and the behavior I was looking for has changed, I think perhaps around the time the options for a client to use the server to connect to LAN/Internet/Both. I have my option set to both. What I want is sometimes to connect to the server for only lan traffic, and sometimes for both.
I connect to my 87U OpenVPN from one of two categories of locations. The first is a public hotspot (e.g., airport), where I want all my traffic to go down the tunnel and out to the internet from my server location. The second is from a secure location, where I want internet traffic not to go down the tunnel, but LAN traffic to go down the tunnel. In the second case I want to use my higher bandwidth.
I use to do this by having the server config not include the push redirect-gateway command, and have two client cfg files, one with the redirect-gateway command, and the other not. Tracert told me that worked as I expected.
In 384.9, it seems that the server config file always contains the push redirect-gateway command. This is true if I manually edit it the config file to comment out the line. If I turn the server off and then on, the config file is regenerated, so I can't figure out how to avoid it.
I use one server on port 1194, and one a backup on port 443, and I would prefer not to have one set for LAN and one for both, although that is possible.
Is there some way to revert to the prior behavior?
