optimal configuration settings
valerima
Dears,
Could you please share what configuration settings you apply?
Do hope not leaving everything on "auto"?
Maybe some settings could be helpful to know and if they interfere with something.
Of course there are no identical recipes, but some basics could be helpful for sure...
As far as 2.4GHz. wireless goes, a big part of it for me was using "inssider" to find out what channels are less used in my neighborhood. For example, my next door neighbors are using channel 6, other neighbors use channel 1 to a lesser extent. So my main channel is set to 11. Security is the usual WPA2/AES. And I have the channel bandwidth set to 20MHz. here, since 40MHz. isn't useful here anyways, too many neighbors.
For 5GHz. wireless, the picture is different. Of course, the 5GHz. signals don't have nearly the range that 2.4GHz. signals do, but the 5GHz. band is clear around here, no interference at all from neighbors. When I've used it, I've set it for the highest channel (since I heard that the higher channels allow higher power *smile*, although from what I've read here results have been different for different people), and set it for 40MHz. channel bandwidth. This gives really good throughput when the range is usable.
I leave the "Wireless Mode" on Auto, since we have both wireless-g and wireless-n devices here. My devices are all wireless-n, but when my family comes over and I don't put them on a guest network, they have some older laptops, etc. and they use wireless-g.
One important factor in getting the best wireless range and throughput (they are related *smile*) with this router is the external antenna orientation. This is a matter of experimenting for your individual environment. You most likely have one or more areas in your house that are the furthest away, where you'd like to get the best signal that you can, that's where you should spend your time playing with antenna orientation (of course).
The wired settings are pretty straightforward, and depend mostly on your need. If you have specific questions there, just ask.
However, I should mention that I don't stream media over wireless very much, I use MoCA for that. We have nice cable in the walls for the cable TV outlets, the double-shielded stuff, and MoCA gives me a very reliable transfer rate both to the Roku box at the entertainment center and to another bedroom where a computer gets a lot of use. It provides the characteristics of a "hard-wired" connection without having to put new ethernet wires in the walls. Did some throughput measurements, and saw a solid, reliable 85Mb/s transfer rate over time, and our use by multiple users doesn't degrade that. We use wireless for tablet and laptop and smart phone connections, and the heavy-duty streaming is via MoCA. I don't think that the newer, higher-throughput 5GHz. speeds will change that for some time for us, since the problem is the range required. We would need a bunch more hardware to cover that range, and I don't have the need for that for the time being. Although the industry would very much like to sell it *smile*.
I am looking for second generation MoCA, but that's been a long time coming, and we don't really need that yet, anyways.
Not sure if this covers what you're asking about, feel free to ask more detailed questions...
channel selection
... the highest channel...
as I am still in the office, could you please remind me where is config point to set up the chanel on this fw?
It was simple on tomato and on ddwrt - if I am not wrong - but looks I did not seen channels clearly listed on this fw?
Wireless -> General tab. Select 5 GHz in the drop down at the top, then set Control Channel to number higher than 100 (default is "Auto", which is also not always optimal).
I have a stronger signal and better range with 5 GHz set on the lowest channel, 36. There are no other 5 GHz networks in the area, so try both extremes before settling with 161.
I as well get better results on lower channels.
Some of my devices will not even connect when using triple number channels so I am now locked onto 48.
Technically, higher channel left untouched mean shorter distance (higher frequency = shorter travel range) indeed, but on the other hand it should allow you to increase the output power more than on the lower channel if the lower channels weren't "good enough" for you.
Otherwise, yeah, that's why there is no "one-size-fit-all" configuration. It depends on your particular case. :)
channel selection
...and on country settings...
Compare how many channels you see while in EU- I see 4 coices only...however in US- range of channels is much bigger...and some other things...as output power, etc.
If there's any question about channel congestion, you might try downloading and running the free "inSSIDer" program to get a really good picture about what channels your neighbors are using. Sadly, the version that also tells you what your microwave oven is doing is expensive. I ended up on channel 3 for 2.4 gHz, partially due to congestion and partially because it created less noise on my BT headset. I ended up at chanel 36 on 5 gHz for the same reason as others.
channels
re inssider currently I had some problems: it required automatic VLAN config (found description on Metageeks) switched on_ through administrative tools panel on W7, but this still is not working properly.
channels
I am not sure, maybe Merlin can advise better- but probably via administration- system you can choose North America some region.
The router region cannot be changed through the webui. The default region is hardcoded in the CFE based on where the router was bought, and you have to manually change a couple of nvram settings if you want to manually change region. Check on the forums, it has been posted a couple of times (most recently in the RT-AC66U forum if I recall).
I don't want to add a setting to the webui to control this, for various reasons, including legal ones.
