Orbi WiFi Speed
Gapmn
I have a bridged DSL modem synced at 152 Mbps Down and 20 up. If I use the modem WiFi (not in bridge mode), I get down load speeds of 125- 137 Mbps. When the modem is in bridge mode and using the Orbi in router mode I get down load speeds of 85 - 120 Mbps. Are there any WiFi settings I could change to increase the speed? I tried adjusting the channels and that did not do anything.
What are you using to measure speed, method and device used, please. And are you measuring with the device near the router or satellite?
Centurylink Speed test, Fast.com, Comcast speed test; Using Mac Book Pro, Surface book, iphone 8.
Thanks. Are you connected to the router or satellite when making the measurements. Should be router. Unplug the satellite temporarily to be sure.
Also be sure you are connected to 5 GHz, not 2.4 GHz.
