GT-BE19000AI Wifi 7 Issue
My bet's still on UPS noise until OP tries to remove it and it doesn't help doing so....
Latest firmware _40383 says it resolves the AiProtection speed penalty...
I have not removed it yet. But I found this error in the logs as well.
Jan 29 14:17:33 kernel: Serdes 8 False Link Up with No RX_C Symbols 0x1022 at 3.c666h at speed 2500Mbps mode USXGMII_M
Jan 29 14:17:33 kernel: ^[[0;30;103mWarning: Serdes at 8 link does not go up following external copper PHY at 26.^[[0m
I suspect the 10 gig Wan Port is glitching out so I switched over to the 2.5 gig wan port. Cable is a new Cat 7.
Kind of regretting the purchase a little.
If possible or if you have a different cable handy, please try it...
It's the AI protection. Disabled and rebooted and its working fine now. Strange that it was only affecting the speed with 320Hz enabled.
maybe not. It's back again with AI off, but seems to be just isolated to one device. The rest are receiving full speeds.
After some more attempts, it appears to be related with PSC Channels. My router was selecting 5 as the control in Auto. Setting it to 37 seems to be the best for device compatibility. I'll keep testing to see if it holds.
That did not work in the long run. Worked well for some devices but still experiencing a significant drop and high ping on one of the Intel BE200 320Mhz devices.
I removed the UPS and it did not improve the situation.
Probably just revert to 160Mhz as it was stable.
