ORBI with Fios - questions and problems
BuyMoreTech
Breaking out separate thread per moderator.
Yes, you can use ORBI with FIOS, but you need to continue to use the Verizon provided router and put the ORBI router into Access Point mode using the Advanced tab - Advanced Setup - Router/AP Mode setting.
Plug the ORBI directly into your FIOS modem or anywhere in your hard wired network.
None here when I had it setup. I plugged in the WAN of Orbi router to LAN/switch port on FiOS. Worked great.
