Overclock RTAC-68U, need help and advices
wsarahan
Hi guys
Let me ask you something
Is it worth make overclock at the 68U mine is working as default, 800/666 (used the Asus tool to get 666) if yes what value for a hot country like mine, Brazil, would you recommend? I read that modt people try 1000/800 or 1200/800.... Should i let stock or try something?
Thanks again guys
Sent from my iPad using Tapatalk HD
fitrst try 1000/666 than 1200/666 ..
1200/800 my not be stable on some routers ...
I just let 1000/666
Will i realize some diference from the stock 800/666 in the real world or not?
