ASUS RT-N56U custom firmware
I thought it would be nice to have a dedicated thread for this firmware.
So far I am liking the newest firmware (RT-N56U_1.1.2.3-010). But for the life of me I can't find the IPv6 settings.Where did it go? I've cleared my browser cache but I can't find it.
Have you tried setting it to 0? On many firmwares this means "never expire". This might be more appropriate for your specific usage.
I only just noticed the donate button on the custom firmware website. I just donated a few bucks. Maybe that can help with getting a longer lease time in the firmware.
Anyway I've been using the last few versions of this custom firmware. It has been much better than the couple of official Asus firmwares and the Asus Beta firmware I tried.
If I understand what you are writing, it is not pulled out, and just adds support for Ipv6.If you want indefinite DHCP leases, just reserve the IP's by MAC address. Or set your devices with static IP's, and adjust your DHCP range.
Example:
Set your DHCP range to 192.168.1.100-254
Statically assign your devices in the 192.168.1.2-99 range.
Setting your DHCP to indefinite leases, somewhat defeats the idea of DHCP. IHMO
Oh, I found out that Pavadan pulled IPv6 out of the current builds for technical reasons. I'm not sure of the actual reasons (language translation software doesn't work for all topics), but he does plan on putting it back in when he figures it out.
And yeah, there's this page here: https://code.google.com/p/rt-n56u/issues/list , although it is not checked as regularly as it should be![]()
Oops. My bad. I could have sworn there was a build with IPv6 at one time. But my excuse is that I've been trying every firmware and I sometimes get confused as to what is in what.Now to the IPv6 support. Actually nobody pulled out IPv6 from this firmware and there's no secret switch. It was never here in the first place.
Translated:Ок, простыня выстлана. Постараюсь следить за темой и в меру своих способностей (и пользуясь этой веткой) разрешать всякие проблемы, вроде бесконечного лизинга IP по DHCP
Добавление от 03.09.2012 14:58:
И вообще надо бы раскрутить это дело. Я чуть позже попробую связаться с топикстартером и попросить его украсить первый псто. А также можно будет сунуть фрагмент на английском в шаблон первого псто нашей ветки с ссылкой туда.
OK, is lined with a bed sheet. Will try to follow the theme and to the best of my ability (and taking advantage of this branch line) to allow all sorts of problems, like an infinite lease IP via DHCP
Addendum dated 03.09.2012 14:58:
And in general it is necessary to untwist it. I'll try later to contact topikstarterom and ask him to decorate the first psto. And also you can shove a piece in English in the first template of our branches with reference psto there.
I noticed that. Hopefully that will improve.And yeah, there's this page here: https://code.google.com/p/rt-n56u/issues/list , although it is not checked as regularly as it should be![]()
Fully acknowledgedThe printing issue described there (ID: 222) exists at least since build 1.1.1.8e-b3 and has been reportet first in April... Hope the flaw will be adjusted soon.
aaronwt
As Guz properly noted, setting indefinite DHCP leases defeats the purpose of DHCP. It is much better to use dynamic leases with static leases in conjunction, e.g. you have a host, which MAC address is known to you. Assign an IP to that specific MAC address manually through the router's WebGUI, so whenever that host enters the LAN, it will get the predefined IP automatically.
All the new MAC address simply get a random IP from specific pool (e.g. 192.168.1.100-192.168.1.254
Also, thank you for your support!
Yeah, well as you understand, that's a matter of printer model<->driver<->OS compatibility. It's not even remotely possible to test every printer model. There's also not much to fix since all printers are expected to work similarly using the same protocols, talking in the same way, etc.
That means you can avoid using proprietary USB-over-Ethernet thing, which Asus has licensed from a third party, and resort to using of TCP/IP printing:
1. Disconnect (or simply disable) your printer from the router and remove the printer from the host OS.
2. ...
Hope this helped you.
In the -010 version the limit was increased up to 64 manually assigned addresses.
Welcome To SNBForums
