Parental Controls ignoring System Time after Daylight Saving changes
slinkoff
As per the title, daylight saving in the UK and the clocks went back an hour. System time on my RT-AC86U shows the correct time on the AiProtection - Time Scheduling page but the blocking is out by an hour.
e.g., it's currently 12:30pm, System Time show the correct time on the router.
Parental Control set to block between 12-13 doesn't work.
If I set it to block between 13-14 then it blocks.
So it's an hour out.
This has only been a problem since the clock went back an hour in the UK.
Tried rebooting? Maybe the parental controls only initialise their timings at boot.
This behaviour has been noted before. It's a limitation of the --kerneltz option that the router uses. See:
http://ipset.netfilter.org/iptables-extensions.man.html
The caveat with the kernel timezone is that Linux distributions may ignore to set the kernel timezone, and instead only set the system time. Even if a particular distribution does set the timezone at boot, it is usually does not keep the kernel timezone offset - which is what changes on DST - up to date. ntpd will not touch the kernel timezone, so running it will not resolve the issue. As such, one may encounter a timezone that is always +0000, or one that is wrong half of the time of the year. As such, using --kerneltz is highly discouraged.
