PCE-AC66U Utility Problem
mojo53
I have just installed the new Asus-AC66 802.11ac card in my new computer Asus P8Z77-V LX LGA1155 ATX Motherboard running Win7 Pro, i installed both the driver and utilities, but when i open the Utilities link on the desktop the window is shrunk down and does not show the full window so i can access all the pages in it to set it up properly and the connection keeps dropping out.
Is this a Win7 issue as i installed another one in my older system running XP pro and it installed no problems and the utilities window opens normally and connects fine to my wireless router and both computers are in the same room ?
Any idea's
PCE-AC66U Utility Window Issue
I had the same problem. Check the Display Size setting (Win 7 Control Panel - Display - Display Size). If it's set at anything above 100% (the default) the GUI window is messed up.
Regards.
Tom
