Pihole and 86u router
OBENZ
Hi, yesterday I decided to use my spare rpi3 foe pihole. Everything is running fine, as I set up the IP of the rpi as the dns on the router. I edited hosts on the pihole to see client's name instead of seeing only the router IP, however doesn't seem to work. Is there any other settings in the router I should append to get it to show client's names instead of the router ?
If the Pi-Hole IP is configured in the router’s WAN DNS, then the router is the source of all queries to the Pi-hole, not the clients.
If you put the Pi-Hole as the only LAN DHCP DNS server, then set the router WAN DNS servers to your ISP or preferred DNS servers, then set the Pi-Hole upstream DNS to be the router IP, it might do what you want.
Disclaimer: never had a Pi-Hole, just a big pie hole. :eek:
Thanks will try that
Now how can I make my vpned client's use the DHCP config?it seems like the VPN server uses Google dns by default and that's causing the client's to be excluded from the pihole
Change DNS mode on your VPN client.
How so?it might be obvious to you but I'm confused. I'm using OPENVPN android app and there's no way to change oy, can't change it on the phone neither as it requests some none local IP as dns address
Pi-hole might become less interesting to quite some people?
One major change in this release is the removal of support for adblock style lists such as Easylist / Easyprivacy, so you may notice a reduction in the number of blocked domains if you have added lists like this in the past. The reason for this change is that these lists were never designed to be parsed into a HOST formatted file, and while it may catch some domains, there are far too many false positives produced by using them in this way. If you have lists in this format, Pi-hole will now ignore them, and attempts to get around the detection will likely end up with a broken gravity list.
https://pi-hole.net/2019/09/21/pi-hole-4-3-2-release-notes/
Yep I know that, which sucks TBH I had a big list now I have to trim down because of these changes but still it's a good tool to monitor tracking and block ads. My smart TV is chatting like crazy with it's manufacturer
