Dear Colleagues,
I have had FTTP internet ( Fiber to the property) installed (in the UK), with a 150Mbps max package. The ISP has provided a separate modem and wireless router Linksys Velop Tri-band AC2200.
All of the clients ( including the TV) have the old WPA2 encryption and wireless N compatibility. I will be streaming 1080/720p HD movies wirelessly through a digital box (1.5gb file size) - currently with the linksys, films do freeze because of buffering. There are also two laptops running Windows 10 with Intel Dual Band AC 7265 internal adapters. The TV and router and digital box will be in the same room. I can’t use an Ethernet cable as the rooms layout won’t allow it.
I want to purchase another router (to replace the Linksys) and use it as an access point / router mode only.
Before the install of FTTP, I used a Broadcom based Router that was stable and very rarely suffered dropouts for ADSL ( Tp-Link TD-W8960N v1 ).
My budget is around £40 ($50 ):
Please can you advise on the following:
1) Will a wireless N router on the 2.4GHz channel maximise my current FTTP package ? Or will a dual-band router on the 5Ghz channel be required for increased wireless throughput for HD streaming?.
2) The Routers I have in mind are:
A) Tp-Link Archer C7 / A7 ( both have Atheros Chipset, which makes me hesitant ) - they are selling for around £30 new ( $40) which for the spec, is expensive. Also no WPA3 for the future?.
B) Tp-Link AX20 v2 ( Wi-Fi 6 and Broadcom chipset and WPA3 and a large memory of 256MB).
C) Tp-Link VR600/ AC1600 ( Broadcom chipset but no WPA3).
D) Tp-Link VR2800 /AC2800 ( Broadcom chipset but no WPA3).
E) If I am mostly streaming HD to the TV, I presume a large RAM / memory capacity on the router is also an advantage.
F) Is WPA3 a must have ? Or is WPA2 still secure enough for my setup if I use a very long password that makes it harder for a ‘dictionary attack’?.
G) Is there any router that I have missed out?.
Any advice on which router will maximise my 150Mbps FTTP package for streaming, stability, signal strength and throughput is appreciated.
Thank you
(Apologies for the long questions).
Thank you
