Please help to diagnose this error
digimon04
I want to install pillow so I do the following:
opkg install python python-pip
and then
HOME=/tmp/mnt/sda1/python pip install pillow
Putty shows:
Collecting pillow
Downloading Pillow-3.4.2.tar.gz (10.8MB)
99% |████████████████████████████████| 10.8MB 3.0MB/s eta 0:00:01Exception:
Traceback (most recent call last):
File "/opt/lib/python2.7/site-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/opt/lib/python2.7/site-packages/pip/commands/install.py", line 299, in run
requirement_set.prepare_files(finder)
File "/opt/lib/python2.7/site-packages/pip/req/req_set.py", line 370, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File "/opt/lib/python2.7/site-packages/pip/req/req_set.py", line 587, in _prepare_file
session=self.session, hashes=hashes)
File "/opt/lib/python2.7/site-packages/pip/download.py", line 810, in unpack_url
hashes=hashes
File "/opt/lib/python2.7/site-packages/pip/download.py", line 649, in unpack_http_url
hashes)
File "/opt/lib/python2.7/site-packages/pip/download.py", line 871, in _download_http_url
_download_url(resp, link, content_file, hashes)
File "/opt/lib/python2.7/site-packages/pip/download.py", line 595, in _download_url
hashes.check_against_chunks(downloaded_chunks)
File "/opt/lib/python2.7/site-packages/pip/utils/hashes.py", line 46, in check_against_chunks
for chunk in chunks:
File "/opt/lib/python2.7/site-packages/pip/download.py", line 563, in written_chunks
File "/opt/lib/python2.7/site-packages/pip/utils/ui.py", line 139, in iter
for x in it:
File "/opt/lib/python2.7/site-packages/pip/download.py", line 552, in resp_read
decode_content=False):
File "/opt/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 353, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/opt/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 310, in read
data = self._fp.read(amt)
File "/opt/lib/python2.7/site-packages/pip/_vendor/cachecontrol/filewrapper.py", line 54, in read
self.__callback(self.__buf.getvalue())
File "/opt/lib/python2.7/site-packages/pip/_vendor/cachecontrol/controller.py", line 275, in cache_response
self.serializer.dumps(request, response, body=body),
File "/opt/lib/python2.7/site-packages/pip/_vendor/cachecontrol/serialize.py", line 87, in dumps
).encode("utf8"),
MemoryError
What does it mean? How can I solve it?
The /tmp folder is held in RAM. If Python is using lots of TEMP space, you may need to change it to use disk space instead of RAM.
/bin/mkdir -p /opt/tmp2
export TEMP=/opt/tmp2
You appear to be running out of memory. Try either of the solutions here: http://stackoverflow.com/questions/29466663/memory-error-while-using-pip-install-matplotlib
Thanks for the help. I tried with --no-cache-dir and it seems there is still error
admin@RT-AC68U-6258:/tmp/home/root# HOME=/tmp/mnt/sda1/python pip --no-cache-dir
install pillow
Collecting pillow
100% |████████████████████████████████| 10.8MB 3.3MB/s
Installing collected packages: pillow
Running setup.py install for pillow ... error
Complete output from command /opt/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/mnt/sda1/entware/tmp/pip-build-yDiLm_/pillow/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /opt/tmp/pip-JuJZlE-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageDraw2.py -> build/lib.linux-armv7l-2.7/PIL
***** ignore for the word counts *****
copying PIL/IcoImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
running egg_info
writing Pillow.egg-info/PKG-INFO
writing top-level names to Pillow.egg-info/top_level.txt
writing dependency_links to Pillow.egg-info/dependency_links.txt
warning: manifest_maker: standard file '-c' not found
reading manifest file 'Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.sh'
no previously-included directories found matching 'docs/_static'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.landscape.yaml'
warning: no previously-included files found matching 'appveyor.yml'
warning: no previously-included files found matching 'build_children.sh'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
writing manifest file 'Pillow.egg-info/SOURCES.txt'
copying PIL/OleFileIO-README.md -> build/lib.linux-armv7l-2.7/PIL
warning: build_py: byte-compiling is disabled, skipping.
running build_ext
File "<string>", line 1, in <module>
File "/tmp/mnt/sda1/entware/tmp/pip-build-yDiLm_/pillow/setup.py", line 753, in <module>
zip_safe=not debug_build(), )
File "/opt/lib/python2.7/distutils/core.py", line 151, in setup
dist.run_commands()
File "/opt/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/opt/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/opt/lib/python2.7/site-packages/setuptools/command/install.py", line 61, in run
return orig.install.run(self)
File "/opt/lib/python2.7/distutils/command/install.py", line 563, in run
self.run_command('build')
File "/opt/lib/python2.7/distutils/cmd.py", line 326, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/opt/lib/python2.7/distutils/command/build.py", line 127, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/opt/lib/python2.7/distutils/command/build_ext.py", line 342, in run
self.build_extensions()
File "/tmp/mnt/sda1/entware/tmp/pip-build-yDiLm_/pillow/setup.py", line 521, in build_extensions
' using --disable-%s, aborting' % (f, f))
ValueError: zlib is required unless explicitly disabled using --disable-zlib, aborting
Command "/opt/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/mnt/sda1/entware/tmp/pip-build-yDiLm_/pillow/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /opt/tmp/pip-JuJZlE-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/mnt/sda1/entware/tmp/pip-build-yDiLm_/pillow/
Yes but now it's progressed further.:)
Try fixing this error.;)
I tried opkg info zlib and it showed that zlib is installed.
If I include the command --disable-zlib, it returns:
admin@RT-AC68U-6258:/tmp/home/root# HOME=/tmp/mnt/sda1/python pip --disable-zlib install pillow
Usage:
pip <command> [options]
no such option: --disable-zlib
Try installing zlib-dev.
If that fails perhaps try this:
pip install pillow --global-option="--disable-zlib"
http://pillow.readthedocs.io/en/3.1.x/installation.html#build-options
After the installation of zlib-dev, I tried HOME=/tmp/mnt/sda1/python pip --no-cache-dir install pillow
This time, it shows:
ValueError: jpeg is required unless explicitly disabled using --disable-jpeg, aborting
I am sure libjpeg has been installed. Therefore, I tried:
HOME=/tmp/mnt/sda1/python pip --no-cache-dir install pillow --global-option="--disable-jpeg"
Still no go. The result is :
/opt/lib/python2.7/site-packages/pip/commands/install.py:180: UserWarning: Disabling all use of wheels due to the use of --build-options / --global-options / --install-options.
cmdoptions.check_install_build_global(options)
Collecting pillow
100% |████████████████████████████████| 10.8MB 3.0MB/s
Complete output from command /opt/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/mnt/sda1/entware/tmp/pip-build-qVUKah/pillow/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" --disable-jpeg install --record /opt/tmp/pip-xIgLvD-record/install-record.txt --single-version-externally-managed --compile:
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: option --disable-jpeg not recognized
Any help is appreciated.
