PMF not really working correctly?
Matthew Patrick
Hi guys. So I'm using AC86U with 386.10. i tried setting PMF to always be required. But using WiFi Analyzer app on my laptop it seems like PMF is only enforced on my main 2.4ghz SSID. The 5ghz one doesn't even have PMF enabled or optional. I think my guest network 1 and 2 (both 2.4 and 5ghz) doesn't show PMF being enabled or optional either. Is it a bug ? Can anyone confirm? Thank you!
PMF will only work on clients capable of using WPA3. If it’s an older device with only WPA or WPA2 then it’s unlikely the device will connect to the network if PMF is set to required. If set to capable then devices that can will use PMF and devices that can’t won’t use PMF.
WPA2/WPA3 mix should give you the option for PMF.
Edit: Can confirm guest network doesn’t show the option for enabling or disabling PMF. WPA3 will use it, WPA2/WPA3 may or may not and since it’s not listed I’m not sure, but theoretically should default to capable.
WPA2 does support PMF though. And my Asus is AC only . So it doesn't have WPA3. And let's just say that it's on capable. It should've set the PMF to capable on all radios right? Both 2.4 and 5ghz. But it seems like it's only doing that in the 2.4ghz. here. See these screenshots when I'm using PMF with the Required option.
My WiFi option on my AC86U :
Main 2.4GHz SSID
Main 5GHz SSID
Guest 2.4GHz SSID
Guest 5GHz SSID
It seems like PMF is only being advertised or even enforced on the main 2.4GHz?
Main 2.4GHz SSID
Main 5GHz SSID
Guest 2.4GHz SSID
Guest 5GHz SSID
To be accurate PMF is required for all new Wifi alliance certified devices. Which typically means they support WPA3 and backwards compatibility with WPA2.
I would try and force the device that is capable of PMF on 5Ghz and see if it says capable. Disable smart connect to do so.
Main 2.4GHz SSID
Main 5GHz SSID
Guest 2.4GHz SSID
Guest 5GHz SSID
@DJones this results doesn't need me to connect to it. It's being broadcasted by the SSID itself. So it shouldn't matter if I'm connected to 5ghz or 2.4ghz right now since it's reading the info being broadcasted by the SSID itself without the need of connecting to it.
For a reference. I tried turning on my WiFi 5 mobile hotspot using my phone. I enabled PMF on my phone and I can see using the wifi analyzer that my phone's WiFi 5 hotspot. Does have PMF enabled on capable. Unlike my AC86U which only does PMF on the main 2.4ghz . That's the weird thing
Ah okay. I see what you mean. Uh yeah that’s odd seems like a bug, curious if it’s happening also on the latest stock. Assuming it’s not a UI bug with Merlin the Broadcom drivers might need to be modified on Asus’s side. Could always leave them feedback or wait and see if @RMerlin sees the issue.
If you disable smart connect you should be able to set 5G individually. Is PMF still disabled then on 5G if you enable it? I found TWT to be disabled on 5G after disabling smart connect (where it was enabled), so maybe this setting is also not correctly replicated to both bands? Just an idea.
And if it's the case, does it stay enabled after you reenable smart connect again?
Yeah idk. The option might only be applying it to the 2.4ghz band only.
I haven't tried that. Can't do it now though. But yeah seems to be a bug or something
Also WPA3 is available on AC routers just doesn’t seem to be that Asus has added support. :/ Considering the routers still get updates it’s kinda unfortunate they haven’t added this functionality.
Tell that to Broadcom. They develop the SDK, only they can add support for WPA3.
As usual doesn’t surprise me it falls back into Broadcom’s lap kinda wish asus would move to atheros just seems more manageable, I think they started to move to proprietary drivers with their ac routers, not sure. Open source would be better.
Anyone with AC86U can try and reproduce the issue? Just Smart Connect and WPA2 only security. Both modes of PMF seems to only apply to the main 2.4ghz. just wanna see if it's happening with others too
