sm00thpapa
My AFCI breakers completely block the Home Plug signal. Do you know of any AFCI breakers that don't?
Do some research before buying new breakers from a different manufacture for your panel. Most panels use a proprietary back plane design.
Even with the manufacture you can't always substitute. For instance Square D has two lines Homeline and SO.
All those power line issues, and that they change as appliances/TVs/dimmers come and go, is why I use MoCA.
Of course, often MoAC isn't practical as there's no easy way to get coax where it isn't. As there's no way to do the same with cat5.
MoCA... you said router... you mean "bridge". Symantics.
MoCA for consumers is becoming rather scarce.
http://www.frys.com/search?search_type=regular&sqxts=1&query_string=moca&submit.x=0&submit.y=0&cat=0
and some Actiontec showed up on Amazon searches.
I have D-Link- early versions. Working OK years later.
http://www.amazon.com/gp/product/B0024FAQL2/?tag=snbforums-20
http://www.ebay.com/itm/New-Netgear-MoCA-Coax-Ethernet-Adapter-Kit-MCA1001-200NAS-/251251864705
Do you mean wired with coaxial cable, or did you mean you actually already have a moca network running on said cables?My entire home is wired with MOCA no Ethernet cables anywhere in my walls. I can't find a MOCA router either as they are doing away with them from what I have been reading.
Glad you figured this out. For the record, powerline can be VERY finacky with working fine and then suddenly not working. Not so with MoCA, so if you have a choice, now you know.
I'm glad you just figured out the wireless way--most of the women I know can't stand a wire.![]()
Thread starter | Title | Forum | Replies | Date |
D | Need help after switching from regular cable to fiber | MoCA, HomePlug, HPNA | 20 | |
W | 'Simple' MoCa Set up not working, need help | MoCA, HomePlug, HPNA | 10 |
Welcome To SNBForums
