Port #1 not active..
Hey, Merlin, lfbb,
I was wondering, considering that my LAN port# 1 is out, if I would Activate/enable The Dual WAN and set the secondary to LAN, would the router randomly select Port#2 or #3 or #4? Does it by default select LAN Port#1?
Just wondering.
Thanks,
Regards.-
No, it asks you which port you want to use.
Merlin,
I did a assign LAN Port #1 -2-3-4 to WAN hoping for a resuscitation of Port #1 with no positive results; just trying anything before the 'ultimate' send back or decide and just live with 3 LAN ports.
Thanks for your help.
Regards.-
Your port is defective, otherwise a factory default reset would have fixed any potential configuration issue.
