port forwarding issue or firewall?
Nathan Owens
i have this as my iptables rules:
#!/usr/bin/bash
#!/bin/bash
MyIP="$(getent hosts ADDRESS_HERE| awk '{ print $1 }')"
  iptables -F
  iptables -X
  iptables -F INPUT
  iptables -P INPUT ACCEPT
  iptables -A INPUT -p tcp -s $MyIP --dport 22 -j ACCEPT
  iptables -A INPUT -p udp -s $MyIP --dport 22 -j ACCEPT
  iptables -A INPUT -p udp -s $MyIP --dport 53 -j ACCEPT
  iptables -A INPUT -p tcp -s $MyIP --dport 53 -j ACCEPT
  iptables -A INPUT -p tcp -s 0.0.0.0/0 --dport 22 -j REJECT
  iptables -A INPUT -p tcp -s 0.0.0.0/0 --dport 53 -j REJECT
If I leave out anything allowing connections from/to local hosts, nmap will say filtered;
If I include anything about allowing connections from my local network it will give port 22 is closed or doesn't even show it in scan
/usr/bin/bash doesn't exist on the router
getent doesn't exist on the router
Are you sure you're posting in the correct forum?
Sorry, I fail to see what this has to do with Merlin's firmware.:confused:
True, I forgot to include picture of my port foward to see if I have it set up correctly atleast.
I've ran a port checker on it and it gives closed and I've also disabled iptables and I still get connection refused
Sorry I must be stupid, I still can't follow you.
What rules are present for this situation?
Lets say things like:
iptables -A INPUT -p tcp -s 192.168.50.0/24 as my router uses 192.168.50.1
But to test to see if it was my firewall blocking it or not I reset the rules so my machine is not blocking anything.
Even though I have port 22 in the WAN->port forwarding, it seems that the router may be the one blocking it
That iptables command looks wrong as that won’t allow any WAN IP from connecting to your SSH server.
Are you sure you have flushed iptables correctly? Are you sure the SSH server is up? Does your ISP filter ports?
I'm sure I did both iptables -F then iptables -X ; sshd is up and before I installed merlin firmware I did have it working, so ISP isn't filtering. I can ssh to the host if i ssh into the router first
Revan# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
I think @kfp is correct. The source address will be an external IP address so it won't match 192.168.50.0/24.
Are you sure that sshd is configured to allow access from outside the local subnet.
For some reason I also can't connect from inside my network either unless I go through router.
If you have enabled SSH access to the router from the WAN then disable it. You can't have two different SSH server's listening on the same IP address and port.
Even if I told the ssh server for router to be on a unique port as well?
That should be OK then.
This sounds like a misconfiguration on computer. Have you checked the hosts.allow and hosts.deny files? Was your previous router using a different IP address range from 192.168.50.0/24? Are you sure your computer is actually 192.168.50.114?
Can you explain what this command is meant to return? I'm assuming that ADDRESS_HERE is actually your computer's IP address, correct? In which case it seems to do nothing useful.:confused:
The commands in your OP don't show a netmask and $MyIP appears to be a single IP address, so this iptables rule doesn't seem the same as the code in the script.
Actually seems to be working fine now, I just disables iptables. Also thankfully I can only connect to it if I am either on my wifi or using vpn. it was sshd issues
