Port forwarding through VPN
DWW
Hi All,
First things first, I am a noob so trying to get my head around some of the language, so please forgive me if my semantics aren't correct, but hopefully my intent is.
I'm wanting to open up some access to a computer on my network (I understand this is done with port forwarding and have been able to establish a limited set of ports to use).
I'd like to make it slightly more secure than just opening up ports to anyone and am curious if it is possible to limit the forwarding of ports to users who are connected to the routers VPN server. That is to say, if I am not connected to the openVPN server that I've setup on my AC68U then I won't be able to access the ports I have opened up to forward to the machine on my network.
firmware version is 384.5
Thanks in advance for the guidance.
DWW
If you are connecting to your router's VPN server then you don't need any port forwarding at all. This is in fact a more secure setup than port forwarding.
So if I connect via my routers vpn server should I just be able to connect to the appropriate IP address like I am within the network?
