Ports remain closed after setting up port forwarding
ducky124
I have an ac86u running the latest Merlin. I just just tried to setup port forwarding to open the port for Qbittorrent. I set everything up but when I got to a port testing site, they tell me my port is closed. I turned off all firewalls and even tried DMZ. Everytime I check my port remains closed. I have tried "netsh firewall show state' from the commmand prompt and it does not list my port as being open. I am completely baffled. Looking for some suggestions. Oh yeah, The P2P software is working perfectly.
Look at the discussion with @bmn1 starting here.
I have tried everything from that thread. I still can not get an open port. As you can see from my qbittorrent log it is finding the port. But whenever I try to scan it from multiple sources it says port is closed. GRC ShieldsUP! says port status is Stealth.
here is the log from Qbittorrent:
5/6/2022 7:23 AM - Detected external IP: 185.202.220.37
5/6/2022 7:23 AM - Successfully listening on IP: ::1, port: UTP/54651
5/6/2022 7:23 AM - Successfully listening on IP: ::1, port: TCP/54651
5/6/2022 7:23 AM - Successfully listening on IP: fe80::a1eb:e37e:6cc6:924c%13, port: UTP/54651
5/6/2022 7:23 AM - Successfully listening on IP: fe80::a1eb:e37e:6cc6:924c%13, port: TCP/54651
5/6/2022 7:23 AM - Successfully listening on IP: fe80::f0d6:cc96:46ee:b358%11, port: UTP/54651
5/6/2022 7:23 AM - Successfully listening on IP: fe80::f0d6:cc96:46ee:b358%11, port: TCP/54651
5/6/2022 7:23 AM - Successfully listening on IP: 127.0.0.1, port: UTP/54651
5/6/2022 7:23 AM - Successfully listening on IP: 127.0.0.1, port: TCP/54651
5/6/2022 7:23 AM - Successfully listening on IP: 192.168.50.230, port: UTP/54651
5/6/2022 7:23 AM - Successfully listening on IP: 192.168.50.230, port: TCP/54651
5/6/2022 7:23 AM - Successfully listening on IP: 10.5.0.2, port: UTP/54651
5/6/2022 7:23 AM - Successfully listening on IP: 10.5.0.2, port: TCP/54651
5/6/2022 7:23 AM - Trying to listen on: 0.0.0.0:54651,[::]:54651
Are you using a VPN?
Are you using the UPnP option in Qbittorrent?
yes to the VPN but tried without it also, and I tried with and without UPnP
yes to the VPN
That's likely why the test is failing.
I run qBittorrent behind a VPN but port forwarding is pointless in such a configuration and the test will fail. So don't waste you time trying to get port forwarding to work. qBittorrent doesn't need it and can work with the VPN anyway.
i thought about it after I replied. the VPN is tunneling past the router.
My problem is the Torrent site I use keeps telling me I'm not connected
