Possible bug, or n00b error - upload vs download
tigerdog
I have installed merlin 380.69 on an AC87U and an AC68U. There's an OpenVPN tunnel between these routers, and file servers that back up periodically from the AC87 side to the AC68 side. During a backup, I expected to see the QoS WAN/LAN bandwidth monitor page's upload bandwidth on the AC87 be matched by the download bandwidth on the AC68. Instead the transmitting AC87 shows upload bandwidth as expected. The AC68 shows upload bandwidth also!
Since I'm going from the 87 to the 68 and there is no other traffic on either LAN, should I not see upload on the AC87 and download on the AC68?
Screenshot attached.
Might be related to the thread I started earlier: https://www.snbforums.com/threads/adaptive-qos-with-vpn-client-download-registers-as-upload.43068/
If you disable QoS, does it go back to normal?
Hi Jack,
It looks like a similar problem, however, QoS is disabled on the AC68, where the issue is seen. QoS is enabled on the AC87, but that displays as expected. If there's a moderator reading, maybe we should combine this thread with the thread mentioned above.
Doug
