Possible to do dhcp reservation on guest networks either on merlin or stock firmware?
snaky69
Is this something that is achievable? Maybe my search skills are lacking but I was not able to find an answer to this
A search of past discussions should have brought up this:
Use guest network 2, 3, or 4 (if available).
See YazFi...
https://github.com/jackyaz/YazFi/wi...e-and-ARP-records#a-note-on-dhcp-reservations
No issues assigning ip addresses to my YazFi guest clients. Did a post on it here:
https://www.snbforums.com/threads/y...inc-ssid-vpn-client.45924/page-32#post-473403
YazFi doesn't work on Aimesh nodes.
If you don't want to use Yaz as discussed below, you can create a dnsmasq.postconf script to add them (requires merlin).
See YazFi...
That's a bummer, I do use Aimesh...
As of mid-2025, YazDHCP meets this need exactly. It replaces the GUI DHCP screen and has a selection to "Allow Guest Network Client Assignments". Once enabled it does exactly what the original GUI DHCP screen should have done. It also enables a higher maximum reservation limit.
https://github.com/AMTM-OSR/YazDHCP
