PPPoE stability
guerrerotook
Hi guys,
My FTH is using PPPoE for connecting to the network and I have my ASUS RT-AC66U connected to the fiber directly.
I have problem with the stability of the connection, always fails and I need to manually change something on the wan setting to force the reconnect.
This is the log, is there something that am I missing?
2014-11-12	22:44:44	emerg	10.10.0.1	user	kernel	Fail to connect with some issues.
2014-11-12	22:44:06	debug		user	kernel	vlan6: add  mcast address to master interface
2014-11-12	22:44:04	notice		user	kernel	Initialization Sequence Completed
2014-11-12	22:44:04	notice		user	kernel	IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
2014-11-12	22:44:04	notice		user	kernel	MULTI: multi_init called, r=256 v=256
2014-11-12	22:44:04	notice		user	kernel	UDPv4 link remote: [undef]
2014-11-12	22:44:04	notice		user	kernel	UDPv4 link local (bound): [undef]
2014-11-12	22:44:04	notice		user	kernel	/usr/sbin/ip route add 10.8.0.0/24 via 10.8.0.2
2014-11-12	22:44:04	notice		user	kernel	/usr/sbin/ip addr add dev tun21 local 10.8.0.1 peer 10.8.0.2
2014-11-12	22:44:04	notice		user	kernel	/usr/sbin/ip link set dev tun21 up mtu 1500
2014-11-12	22:44:04	notice		user	kernel	do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
2014-11-12	22:44:04	notice		user	kernel	TUN/TAP TX queue length set to 100
2014-11-12	22:44:04	notice		user	kernel	TUN/TAP device tun21 opened
2014-11-12	22:44:04	notice		user	kernel	Socket Buffers: R=[118784->131072] S=[118784->131072]
2014-11-12	22:44:04	notice		user	kernel	Diffie-Hellman initialized with 512 bit key
2014-11-12	22:44:04	notice		user	kernel	library versions: OpenSSL 1.0.0n 6 Aug 2014, LZO 2.08
2014-11-12	22:44:04	notice		user	kernel	OpenVPN 2.3.4 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Sep 20 2014
2014-11-12	22:44:02	emerg	10.10.0.1	user	kernel	WAN was restored.
2014-11-12	22:44:01	info		user	kernel	device tun21 entered promiscuous mode
2014-11-12	22:44:01	info		user	kernel	tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
2014-11-12	22:44:01	info		user	kernel	tun: Universal TUN/TAP device driver, 1.6
2014-11-12	22:44:00	warning		user	kernel	Interface tun21 doesn't exist
2014-11-12	22:44:00	warning		user	kernel	Interface tap21 doesn't exist
2014-11-12	22:44:00	notice		user	kernel	SIGTERM[hard,] received, process exiting
2014-11-12	22:44:00	notice		user	kernel	/usr/sbin/ip addr del dev tun21 local 10.8.0.1 peer 10.8.0.2
2014-11-12	22:44:00	notice		user	kernel	Closing TUN/TAP interface
2014-11-12	22:44:00	notice		user	kernel	/usr/sbin/ip route del 10.8.0.0/24
2014-11-12	22:44:00	err		user	kernel	event_wait : Interrupted system call (code=4)
2014-11-12	22:44:00	notice		user	kernel	Listening for NAT-PMP/PCP traffic on port 5351
2014-11-12	22:44:00	notice		user	kernel	HTTP listening on port 48217
2014-11-12	22:43:59	emerg		user	kernel	waitting "stop_vpnserver1" via ip-up ...
2014-11-12	22:43:59	emerg		user	kernel	ip-up 13999:notify_rc start_vpnserver1
2014-11-12	22:43:59	emerg		user	kernel	ip-up 13999:notify_rc stop_vpnserver1
2014-11-12	22:43:58	notice		user	kernel	shutting down MiniUPnPd
2014-11-12	22:43:58	emerg		user	kernel	waitting "stop_upnp" via ip-up ...
2014-11-12	22:43:58	emerg		user	kernel	ip-up 13999:notify_rc start_upnp
2014-11-12	22:43:58	emerg		user	kernel	ip-up 13999:notify_rc stop_upnp
2014-11-12	22:43:58	debug		user	kernel	vlan6: add  mcast address to master interface
2014-11-12	22:43:58	info		user	kernel	using nameserver 8.8.8.8#53
2014-11-12	22:43:58	info		user	kernel	read /etc/hosts - 5 addresses
2014-11-12	22:43:58	info		user	kernel	asynchronous logging enabled, queue limit is 5 messages
2014-11-12	22:43:58	warning		user	kernel	warning: interface ppp1* does not currently exist
2014-11-12	22:43:58	debug		user	kernel	compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC
2014-11-12	22:43:58	info		user	kernel	started, version 2.72test3 cachesize 1500
2014-11-12	22:43:58	info		user	kernel	exiting on receipt of SIGTERM
2014-11-12	22:43:58	emerg		user	kernel	apply the nat_rules(/tmp/nat_rules_ppp0_vlan6)!
2014-11-12	22:43:58	emerg		user	kernel	ip-up 13999:notify_rc start_firewall
2014-11-12	22:43:58	warning		user	kernel	SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
2014-11-12	22:43:58	err		user	kernel	Failed to get IP for interface ppp0
2014-11-12	22:43:58	err		user	kernel	ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
2014-11-12	22:43:58	notice		user	kernel	remote IP address 192.168.144.1
2014-11-12	22:43:58	notice		user	kernel	local  IP address
2014-11-12	22:43:58	notice		user	kernel	peer from calling number  authorized
2014-11-12	22:43:58	notice		user	kernel	CHAP authentication succeeded
2014-11-12	22:43:58	info		user	kernel	CHAP authentication succeeded
2014-11-12	22:43:58	notice		user	kernel	Connect: ppp0 <--> vlan6
2014-11-12	22:43:58	info		user	kernel	Using interface ppp0
2014-11-12	22:43:58	warning		user	kernel	Connected to  via interface vlan6
2014-11-12	22:43:58	info		user	kernel	PPP session is 2364 (0x93c)
2014-11-12	22:43:58	notice		user	kernel	pppd 2.4.5 started by admin, uid 0
2014-11-12	22:43:58	info		user	kernel	RP-PPPoE plugin version 3.11 compiled against pppd 2.4.5
2014-11-12	22:43:58	info		user	kernel	Plugin rp-pppoe.so loaded.
2014-11-12	22:43:58	info		user	kernel	vlan6: dev_set_allmulti(master, 1)
2014-11-12	22:43:44	info		user	kernel	using nameserver 8.8.8.8#53
2014-11-12	22:43:44	info		user	kernel	read /etc/hosts - 5 addresses
2014-11-12	22:43:44	info		user	kernel	asynchronous logging enabled, queue limit is 5 messages
2014-11-12	22:43:44	warning		user	kernel	warning: interface ppp1* does not currently exist
2014-11-12	22:43:44	debug		user	kernel	compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC
2014-11-12	22:43:44	info		user	kernel	started, version 2.72test3 cachesize 1500
2014-11-12	22:43:44	info		user	kernel	exiting on receipt of SIGTERM
2014-11-12	22:43:44	emerg		user	kernel	apply the nat_rules(/tmp/nat_rules__vlan6)!
2014-11-12	22:43:41	debug		user	kernel	vlan6: add  mcast address to master interface
2014-11-12	22:43:41	debug		user	kernel	vlan6: del  mcast address from master interface
2014-11-12	22:43:41	debug		user	kernel	vlan6: del  mcast address from vlan interface
