Here's a pretty prompt with some nice "login" conveniences.
Here's the profile, in "/jffs/etc/profile":
Then add this to "/jffs/scripts/init-start", to link (or copy) it into the $HOME directory at boot:
If needed, copy it to "~/.profile".
Tested and working spectacularly on an AC68U.
Updating the PATH is useful for scripts like these - https://www.snbforums.com/threads/cryptographic-hash-script.59988/
Here's how this pretty-prints the uptime - https://www.snbforums.com/threads/pretty-print-uptime.59986/
Here's how this pretty-prints the boot time - https://www.snbforums.com/threads/display-boot-time.59984/
Of course the prompt can be customised to your liking, but there are limitations in busybox, so a "normal" bash prompt may not work as expected.
## there's no .login support in this busybox shell
## so use this as a test to see if this is a fresh login
## otherwise, just skip this conditional list when this file is sourced
[ ${HISTFILE} ] || {
## alternative test, if $HISTFILE isn't working as expected: [ ${_} == ']' ]
## below here, within this curly-brace list, is what's done during a fresh login
echo
echo "curent time: $(date)"
## calculate and display boot time
echo -n "boot time: "
date -d@$(( $( date +%s ) - $( cut -d. -f1 < /proc/uptime ) ))
## display uptime and load averages
eval "echo uptime: $(date -ud@$( cut -d. -f1 < /proc/uptime ) +'$((%s/86400)) days %H:%M:%S')"
echo -n "load avg: "
cut -d ' ' -f1-3 < /proc/loadavg
echo
## display filesystem stats for /tmp and /jffs
df -h /tmp /jffs
echo
## display used and available space in nvram
echo -n "nvram " ; nvram show > /dev/random
echo
## set up a nice prompt
## unfortunately this version of busybox chokes on multi-line prompts
export PS1="\[\e[35m\]\h\[\e[m\] \[\e[36m\]\w\[\e[m\]\[\e[97m\] \\$\[\e[m\] "
export PS2="\e[91m>\e[m "
## add custom scripts to the PATH
PATH=${PATH}:/jffs/bin
## set up fancy prompt stuff
/bin/ln -s /jffs/etc/profile /root/.profile
ln -s /jffs/etc/profile ~/.profile
