Problem with RT-AX58U after 3.0.0.4.388 upgrade
bmn1
After upgrade to 3.0.0.4.388 on my RT-AX58U I got serious problem with the web UI when I activate WireGuard. I've tried both Factory Reset and Firmware Restoration, but the same problem appears when I enable WireGuard. I've even tried installing Merlin, but then WireGuard doesn't work. Anyone else encountered this problem and found a solution?
What's the problem?
I updated AX58U V2 to 3.0.0.4.388_22525 a couple of weeks back and am having issues with the 2.4Ghz SSID.
I connect all my smart device to this SSID, and recently it's been dropping the connections eg. smartcam shows as offline as it doesn't have internet access.
I looked at the available SSIDs and I can see it, but when I connect to the 2.4Ghz SSID, the signal shows like this:
That is directly next to the router.
There is no issue on the 5Ghz SSID, only the 2.4Ghz one.
I then checked the connected devices on that SSID through the admin web portal, and I can still see them as connected (smartcam, lights, water heater etc.)
But the devices doesn't seem to be able to get internet access.
I need to restart the router and it will be back to normal, but then after a few hours it will happen again.
Indicator shows nothing abnormal.
Here is the wireless log for the 2.4Ghz SSID:
Anyone having issues like this and have a solution?
If I download an older firmware and do the 'update' via the admin web portal will it accept if it's an older firmware?
Is this a hardware issue?
Thanks!
