Problem with run script after VPN client connected
kondratiy
i'm use RT-N66 with 3.0.0.4.374.35_4 merlin
In older versions of the client when connected to an external PPTP VPN - run script nat-start from /jffs/scripts/ , this is not happening now, and it became impossible to prescribe a route between networks. For yet I do not know - it's a bug or have done so intentionally.
Now scripts will run - but for a different logic, I prescribe a simple route in the new build?
route add -net 192.168.2.0/24 ppp10 ?
Ps All scripts run fine, but too early, when there is no interface
Jan 5 23:53:07 pptp[1771]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Jan 5 23:53:07 pptp[1771]: pppd 2.4.5 started by admin, uid 0
Jan 5 23:53:07 pptp[1771]: Using interface ppp10
Jan 5 23:53:07 pptp[1771]: Connect: ppp10 <--> pptp (83.149.9.218)
Jan 5 23:53:07 pptp[1771]: MPPE 128-bit stateless compression enabled
Jan 5 23:53:07 pptp[1771]: found interface br0 for proxy arp
Jan 5 23:53:07 pptp[1771]: local IP address 192.168.1.1
Jan 5 23:53:07 pptp[1771]: remote IP address 192.168.1.50
<HERE OLD SCRIPT RUN PLACE>
nat-start is only executed when the NAT rules are being modified and reapplied to the router. If previously you were able to configure routes for PPTP clients through that script then it was just lucky timing - that script doesn't specifically run on PPTP clients connecting.
The search for solutions on the Internet showed that this was not a happy man just me.
How can I solve this problem in another way? Need to add a route after raising VPN connection.
Ps For people who are not well versed in networking, pptp is more preferable than openvpn for such simple things.
If you don't mind the fact that PPTP can be compromised quite easily these days with the various vulnerabilities of the protocol.
And when it comes to custom routing, OpenVPN is far more suited for it.
