spdMerlin Problems installing spdMerlin on Asus RT-AX86U_Pro
kevin2296
I bought an Asus RT-AX86U_Pro to replace my AC86U.
Now I installed de default applications (Diversion/Skynet/FlexQos) and spdMerlin.
When I run the install script I got the message "mv: can't rename '/tmp/spdmerlindata.zip': No such file or directory".
Then the speedtest runs and the Router going to reboot..
After that I run again the install line "/usr/sbin/curl -fsL --retry 3 "https://jackyaz.io/spdMerlin/master/install/spdmerlin.sh" -o /jffs/scripts/spdmerlin && chmod 0755 /jffs/scripts/spdmerlin && /jffs/scripts/spdmerlin install" and then I can see the webUI.
But speed logging doesnt work and I cannot change settings (not saving..)
Is this a know issue on the 3004.388.4 firmware?
I already search on it but nothing to find..
Full install log as attachment (to many characters for message)..
There is no default "applications". You perhaps use on-router DNS-blocking with Diversion, but you may not need IP-blocking with Skynet (this is not a firewall), FlexQoS may not work on this router anymore and spdMerlin is not supported by the developer anymore. Search again for more information.
Yep, I found some other topics on this model...
The first link has nothing to do with addon scripts, and the second link points to this thread. :rolleyes:
Are you questioning SNB's "better search" feature?? Lol
