Greetings all! First post here.
I've finally decided to brave the fearsome beasties that live under my house and run Cat6 ethernet cabling from my office to two other rooms. One run will be about 50 feet and the other run will be around 75 feet. I'm purchasing preterminated lengths from Amazon because I don't want to bother with the crimping and I plan to support the cables along their run every four to five feet with 3/4 J hooks. Since it is under my house I am planning on using Cat6 cable that is rated for direct burial. That may be a tad on the side of overkill but better safe than sorry I figure. Here is a link to the cable I plan to purchase--
http://www.amazon.com/dp/B0087EG8DO/?tag=snbforums-20
I'll be using keystone jacks at each end and popping them into the appropriate wallplates. Does anyone see any problems with this plan? Any thoughts or input on this course of action are appreciated. Many thanks.
