Is there a way to delete the Statistics and Web History in the Webif? Is there a way to pure a date range?
I'm guessing as of now there is not...? If not how can I go about doing it by ssh?
Go to an embarrassing web-site perhaps?
That clears the Web History, but not the statistic...(I did the reboot and a hard reboot).That website list will clear after a reboot.
Did you clear your web browsers cache?
Seems like this is the perfect time to use a saved config file, reset to factory defaults and then restore the config file you saved?
Which specific statistics are you referring to? They are all stored in different places.
Sent from my Nexus 5X using Tapatalk
The Web History tab on the Adaptive QoS menu clears on a reboot, but the statistic tab on Traffic Analyzer menu( The charts) do not.
I'm looking to clear the charts on the Traffic Analyzer menu.
Thanks![]()
Traffic Analyzer content is stored in /jffs/traffic.db. Make sure Traffic Analyzer is disabled, them delete that file over SSH.
How do I use SSH to access my router file structure? Is there a guide or discussion that will lead to enlightenment?Traffic Analyzer content is stored in /jffs/traffic.db. Make sure Traffic Analyzer is disabled, them delete that file over SSH.
If you're not good with a command line, try Winscp (For windowz) Its gui based. Just make sure you change the protocol to scpHow do I use SSH to access my router file structure? Is there a guide or discussion that will lead to enlightenment?
Welcome To SNBForums
