Putty/SSH command to turn port forwarding on/off.
  • Thread starter Thread starter Deleted member 27741
  • Start date Start date
D
Guest
I have what is probably an easy question that has already been answered. Is there a command to turn port forwarding on/off I can use through SSH? I am assuming it would be equivalent to clicking the yes/no radio buttons and apply on the port forwarding page in the gui.
Ok I think I may have found it. Looks like vts_enable_x=1 is port forwarding on and vts_enable_x=0 is port forwarding off. So log into the router via SSH and use the following commands:
nvram set vts_enable_x=1
nvram committ
service restart_firewall
That should do the trick to turn it on, to turn it off use the following:
nvram set vts_enable_x=0
nvram committ
