qos + bandwidth limiter? qos + load balancing?
EspHack
why is that not possible? if i want to limit a specific device's bandwidth it has to be that over any QoS, and if i want dual wan load balancing it disables the entire adaptive QoS and "aiprotection" sections
is that a limitation on my ac87u? could i make all those features work at once on a higher end router?
Facing the same issue on AX-11000. As soon I turn on dual wan load balancing, AIProtection and QoS are turned off.
