qos_rulelist vs qos_ruleset
ajoyner
What is the difference between these two values? I wanted to modify the mac address of an existing QOS rule. Changing the value of qos_ruleset didn't change anything in the UI, where as changing qos_rulelist did. I changed them both to be safe, but was just curious if changing qos_ruleset was necessary.
I did a grep and can't find any reference to 'qos_ruleset' in the current code. Possibly they changed a name somewhere or it's embedded in one of the adaptive closed source components. When is the last time you did a reset to factory defaults? (if the former case, it will disappear).
Thanks for the reply.
I typically reset to defaults after every update, but then I use the "NVRAM Save/Restore Utility" found on this site to restore my settings. If you aren't finding it, I guess it may be something that was left behind in one of the previous builds and is no longer used. I would assume it's safe to ignore then.
