Rule 3 , if you don't want to answer don't . Snark ain't needed , maybe you need a breakRule #1, search is your friend.
Rule #2, if you don't know what something is, don't change from the default (usually 'off').
https://www.google.ca/search?q=Link...u&ie=&oe=&gfe_rd=cr&ei=uykpWM_dHrOE8Qf01bqwBw
Thanks .Only use this if you have a device that supports link aggregation (has 2 or more network cards) and know what you are doing![]()
Welcome To SNBForums
