Question on Traffic Monitor Per Device - Date Selection
Parafly
I enabled it in options and hooked up a USB drive. However, I don't have the option to pick date ranges, the boxes FROM and TO are unselectable and therefore I can't get any data on it. This is for both Monthly and Daily logs. Any idea how to fix this?
I'm using Chrome on Win7, btw.
Also, is there any way to get data during a window of time (vs. just day / month)? That would be a really cool feature for troubleshooting issues if you know they happened during some period of time :)
Most likely because there is a problem with the location of your database. Check System Log for any error related to rstats or cstats.
Keeping track of all that time-based data would require far too much resources. It would imply that the database would contain multiple datapoints for every single device and every single day - that would be unmanageable on a router with 256 MB of RAM.
Thanks rmerlin. Appreciate your effort on this firmware, by the way!
Found this in the log:
Jun 3 01:19:35 cstats[329]: Problem loading /mnt/USB_DISK/tomato_cstats_ac220b3109a8.gz. Still trying...
Any tips on how to get this fixed? Is my path just wrong? The home page of the router whos General USB Flash Device shown with available space on it in the USB slot.
Make sure the path is correct, and that you did check the option telling it to create a new database, under Tools -> Other Settings. This has to be done separately for both regular traffic monitoring and IPTraffic.
