Radio off command
lavoied
Hello all,
My goal is to enable/disable WIFI with a cron job on one of my aimesh node. I connect via ssh to my aimesh node and I can't even make work simple command like "radio off", "wl radio off", "wl -i eth1 radio off"
when I run them, wifi is still enabled.
After using those command, how can I make sure that radio is actually off? For now, the only way is by using ifconfig and the gui
my router ac66u_b1
Thanks for your help!
