Recommendation for a robust outdoor wifi AP
ddaenen1
I urgently need an outdoor access point. Since i exchanged my Asus AC-88U that was also covering the outdoor patio with a WAP571 my signal strength outside has been reduced significantly. I was on the hunt for a 2nd hand WAP571E but they are very hard to come by and i cannot justify the delay any longer so i am looking for something else that plays along well with my setup of 4 WAP571 AP's in-house. I have the ability to run a CAT6 UTP cable to the outside and connect it directly to my Netgear GS752TP POE+ switch so i am looking for a decent POE(+) outdoor AP that doesn't cost an arm and a leg that does the trick.
Any recommendations?
I would think if you mix a different brand then your roaming may not work as well. Maybe use an outside SSID.
