Recommendation's Needed Dual Wan+ Dual Band + AC
Moulders
Hi Guys,
So I've been looking to upgrade my home network Which currently consists of two network connections one BT the other Virgin I currently get speeds of:
Virgin: 121mbps down and 12mbps up
BT: 20bmps down and 3 mbps up
this is using the hardware the ISP provides.
both devices are right next to each other which cant help wireless performance.
Initially I was looking at getting a Draytek 2925n but this doesn't support AC wireless and is probably overkill on the firewall front.
More recently I've been looking at the ASUS RT-AC68U which appears to be able to do Dual Wan? It looks promising but I wanted to get some other opinions first.
