I have the main router 86u connected via AiMesh to 68P with the following wireless settings under professional tab for both 2.4 and 5G networks. Do they look right for the setup or some of the settings need adjusting? Thank you guys in advance.
For 2.4 disable Mimo, exlpicit and universal beamforming, for 5ghz disable all except 802.11ac beamforming. If you're using aimesh , they recommend using roaming assistance.
