Recover deleted photos on sd card?
Pyroguee
hello everybody!
I need to find a program that can recover data from an SD card(LG G3). I have deleted some pics from the phone and I heard I can get a program to get them back. I tried a few program called photorec but it didn't work. Any chance to get back the photos? thanks
Just as a reminder, take the card out of the device and set it aside - anything that writes to that card will complicate any chance of recovery.
Thanks for the tip. I already took it out and tested the programs suggested above.
hello everybody!
if u have a pre installed recovery software u can try something
But the other way is simply plug in to a computer or remove the sd card and connect to a computer and open the folder named DCIM and there u can see two folders....open thumbnails. and there u can see preview images.....but it lacks quality.....
So, you can try Android data recovery to scan your SD card and try to recover deleted photos from Android SD card.
