ntpMerlin Redirect all NTP queries to chrony - except one client
nephilim
I have an AiMesh setup with an AX-86U Pro as main router running chrony. One of the network clients is a Raspberry Pi with attached Adafruit GPS/PPS module. This client runs a chrony instance, which is using the GPS as refclock and a handful of public NTP servers with the "noselect" option for monitoring purposes. The chrony instance on the AX-86U uses the Raspberry as single source (and the same "noselect"ed public servers for monitoring) and acts as time server for my local network. Apart from a few glitches (which I will request your advice for in a separate thread) this is running fine.
As I have several network clients with hard-coded NTP-servers I would like to redirect all NTP traffic through the AX-86U - except the Raspi as this would trigger the loop detection in the Raspi's chrony instance. For that reason I am not using the redirect option in the ntpMerlin script. How can I set up the redirection for all but one IP of my local network?
The GUI redirection option adds this line to the end of NAT table:
-A PREROUTING -i br0 -p udp -m udp --dport 123 -j REDIRECT --to-ports 123
You need to create a nat-start script which inserts an exception before that rule:
iptables -t nat -I PREROUTING -s 192.168.1.99 -p udp --dport 123 -j ACCEPT
Change 192.168.1.99 as required.
Thank you - that works!
Apologies, I was too quick. I added the line to the (empty) /jffs/script/nat-start file and enabled ntp redirection in ntpMerlin. This appended the invocation of the ntpmerlin script to that file. After reboot I see that the ntp redirection was on top of the iptables rules, hence I slightly changed the exception and added tcp (because ntpmerlin also creates a rule for tcp) such that the nat-start file looks like this
#!/bin/sh
/jffs/scripts/ntpmerlin ntpredirect # ntpMerlin
iptables -t nat -I PREROUTING 1 -s 192.168.1.105 -p udp --dport 123 -j ACCEPT
iptables -t nat -I PREROUTING 2 -s 192.168.1.105 -p tcp --dport 123 -j ACCEPT
And this is the prerouting chain
# iptables -t nat -n -L
Chain PREROUTING (policy ACCEPT)
target     prot opt source               destination
ACCEPT     udp  --  192.168.1.105        0.0.0.0/0            udp dpt:123
ACCEPT     tcp  --  192.168.1.105        0.0.0.0/0            tcp dpt:123
DNAT       tcp  --  0.0.0.0/0            0.0.0.0/0            tcp dpt:123 to:192.168.1.1
DNAT       udp  --  0.0.0.0/0            0.0.0.0/0            udp dpt:123 to:192.168.1.1
GAME_VSERVER  all  --  0.0.0.0/0            91.64.48.100
DNSFILTER  udp  --  0.0.0.0/0            0.0.0.0/0            udp dpt:53
DNSFILTER  tcp  --  0.0.0.0/0            0.0.0.0/0            tcp dpt:53
Still the chrony instance on the raspi (192.168.1.105) is unable to poll the public servers. What have I missed?
What I forgot to add... when redirection is enabled via ntpMerlin the following rule is showing up in iptables -S
-A FORWARD -i br0 -p udp -m udp --dport 123 -j REJECT --reject-with icmp-port-unreachable
-A FORWARD -i br0 -p tcp -m tcp --dport 123 -j REJECT --reject-with icmp-port-unreachable
Sorry, you said you weren't using the ntpMerlin redirect. I don't know anything about how that works. I was only referring to what the standard GUI option does.
No, that was my mistake! I was wrongly assuming that I could combine your exception advice with activating redirection via ntpMerlin. I have again switched off ntpMerlin and use the following nat-start file:
#!/bin/sh
iptables -t nat -I PREROUTING -i br0 -p udp -m udp --dport 123 -j REDIRECT --to-ports 123
iptables -t nat -I PREROUTING  -s 192.168.1.105 -p udp --dport 123 -j ACCEPT
iptables -t nat -I PREROUTING  -s 192.168.1.105 -p tcp --dport 123 -j ACCEPT
which results in
REDIRECT   udp  --  0.0.0.0/0            0.0.0.0/0            udp dpt:123 redir ports 123
which I guess is what I was attempting to achieve.
Thanks for your patience.
Alternatively, If you do not have that client saved to your static list, you could use the known source MAC addr of the client.
e.g.
-A PREROUTING -i br+ -p udp -m udp --dport 123 -j NTPREDIR
-A PREROUTING -i br+ -p tcp -m tcp --dport 123 -j NTPREDIR
-A NTPREDIR -m mac --mac-source XX:XX:XX:XX:XX:XX -j RETURN
-A NTPREDIR -j DNAT --to-destination 192.168.1.1
I setup my own custom chain called NTPREDIR. (Similar to how DNS Directors client filter list works.)
Here is what this looks like in my firewall script.
{ /usr/sbin/iptables -t nat -F NTPREDIR && /usr/sbin/iptables -t nat -X NTPREDIR; } 2>/dev/null
/usr/sbin/iptables -t nat -N NTPREDIR 2>/dev/null
for i in -D -A; do
/usr/sbin/iptables -t nat $i PREROUTING -i br+ -p udp -m udp --dport 123 -j NTPREDIR 2>/dev/null
/usr/sbin/iptables -t nat $i PREROUTING -i br+ -p tcp -m tcp --dport 123 -j NTPREDIR 2>/dev/null
/usr/sbin/iptables -t nat $i NTPREDIR -m mac --mac-source XX:XX:XX:XX:XX:XX -j RETURN 2>/dev/null
/usr/sbin/iptables -t nat $i NTPREDIR -j DNAT --to-destination 192.168.1.1 2>/dev/null
done
Adapt 192.168.1.1 to be the address of the NTP service. Adapt XX:XX:XX:XX:XX:XX to be the mac addr you want to not redirect NTP for.
adapting your current script.
#!/bin/sh
iptables -t nat -I PREROUTING 1 -m mac --mac-source XX:XX:XX:XX:XX:XX -p udp --dport 123 -j ACCEPT
iptables -t nat -I PREROUTING 2 -m mac --mac-source XX:XX:XX:XX:XX:XX -p tcp --dport 123 -j ACCEPT
Although I am not sure if --mac-source will work for this instance.
Edit, Good news it does!
