Redirect external NTP calls to local NTP server?
cmkelley
Except of course, NTP calls from the NTP server itself. :)
I have a local NTP server on my network (not the router itself). For silliness where specific ntp servers are hard-coded into devices, is it possible to redirect all ntp traffic to my local server and allowing only my local ntp server itself (which has a fixed IP) to reach out to the external internet?
Seems like an IPTables thing? Is it simple or difficult? We seem to have a couple IPTables wizards here.
I use this...it seems to work (I think)
iptables -t nat -A PREROUTING -p udp -m udp --dport 123 -j DNAT --to-destination 10.14.16.1
It's been a while since I actually tested it, so it may no longer (or never did) work fully!
Do a search for raspberrypi ntp. It has the instruction that work. I got it working on my ntp server. All my devices are automatically routed to it.
You'd have thought I would have thought of that, since my NTP server is an R-Pi. 'Doh!
Thanks Jack, I'll give it a try!
Granted, I know zero about iptables, but unless there's underlying magic, how does that allow the one NTP server to reach external servers? Doesn't it just reflect the NTP server's requests back to itself?
Good question - it seems OK on my setup since ntpd is running on the router - might need to specify interfaces for the rule
Exactly right. I think Jack's assumption was that your internal NTP didn't rely on NTP for itself. i.e. it has a GPS receiver or some such. There's been a few projects like that. If your internal NTP server uses NTP itself then you'd have to make an exception for its IP address.
Like this?
iptables -t nat -A PREROUTING -p udp -m udp --dport 123 ! -s 10.14.16.10 -j DNAT --to-destination 10.14.16.1
Yes, my internal NTP does get time primarily from a GPS receiver, but it also goes out and gets internet time, just in case something stupid happens like one of our cats chewing through the GPS antenna cable. :)
