YazFi Redirecting guest network NTP traffic to ntpMerlin
Serkan K.
Hello,
I have gadgets like chromecast, appletv, some tablets on a dedicated guest network. Is it possible to redirect ntp traffic from the guest network to ntpMerlin?
I configured chronyd to serve the guest network ip range with:
allow 192.168.4.0/16
and selected "Toggle redirect of all NTP traffic to ntpMerlin"
in YazFi following set to true
FORCEDNS
ONEWAYTOGUEST
CLIENTISOLATION
I check if guest clients get their time from ntpMerlin with
chronyc clients
but, I've never seen a guest ip.
Thanks.
Hello,
This currently only applies to br0, primary LAN, traffic. YazFi sets the DHCP option for the NTP server to be used but it probably isn't being respected by the clients. I'll add this as a feature request, if redirect is enabled (either ntpmerlin or firmware), YazFi should follow suit.
Thank you very much. I appreciate all of the great and useful work you've put into all of your addons.
