I had been using ASUSwrt-Merlin 374.40. I had to reboot, and when I did I noticed my OpenVPN client1 would not start. The log file showed an error message about a missing private key, which was strange, because it was working before the reboot. I checked the GUI, and the private key file was blank. I uploaded the .ovpn file again, but the private key remained blank. I cut and pasted the private key, but it remains blank after I close the key window. So I upgraded to 374.42 and I found the same behavior. I checked that the private key is less than the 3499 limit (it is less than 2500 bytes). So now I am stumped as to what could be wrong. There are no error messages in the system log. client2 is working fine. Could the router be out of memory to hold my private key? What can I check (e.g. with ssh?) to help determine the problem?
Suggestions eagerly awaited, as right now I'm dead in the water without my client1 VPN.
