Remote Logging sometimes broken
corgan2222
Hey,
after i configured a central logging server on a root server and send the syslog from around 20 clients, i saw some strange folders. After some research i found the problem. The syslog on my RT-AX88U with 384.10_2 is broken sometimes.
1. The format goes crazy. Sometimes the date is twice.
on the central logging server the system breakes, because the logs going to a complete nonsense folder.
2. Sometime the Date is May 5 07:05:08. Sometimes on reboot, but sometime completly random after some hours. This happend all on the router bevor sending. Im logging from rsyslog into influx and this breaks the metrics. :/
i hade searched on the forum and there is a thread with the same date problem, but without an answer.
https://www.snbforums.com/threads/errors-in-syslog-since-384-10_2-upgrade.56213/
I have a USB Stick mounted in the router.
Any Ideas how to fix this?
This is normal. The router has no battery-backed up RTC, so clock gets reset to a fixed date on reboots, until ntpd can kick in and set the clock.
