Remove downloadmaster dependencies
nikkoaki
Greetings.
I was messing around in the gui and installed downloadmaster by mistake. I noticed it also installed a bunch of dependencies.
Removing the package (in the gui or by ssh) does not remove the dependencies. "--force-removal-of-dependent-packages" isn't working either.
ipkg info gives me "Depends: uclibc-opt, zlib, libevent, ncurses, libxml2, libuclibc++, libsigc++, libpar2, pcre, spawn-fcgi, readline, wxbase, asuslighttpd"
I could remove them one by one but i don't know if some of them are being used by other programs.
Is there an easy way to remove just the ones installed by downloadmaster?
Best to remove the optware folder from the USB disk, and reboot to start over again.
C Does updating merlin remove installed packages? Asuswrt-Merlin 1
