Repeater/Bridge to Guest Network broken on 386.3
daleprc
After upgrading to 386.3 from 386.2_6, I noticed my guest router, which connects to my guest wifi in repeater mode, no longer gets assigned an IP from the main network and instead runs as 192.168.1.1.
Main setup: 3x AC68U in AiMesh with a guest network in 5G band.
Guest setup: 1x AC68U in repeater mode, wirelessly connected to the guest network.
Observations:
1. With main setup on 386.3, issue reproduces regardless of guest router version and resetting the guest router didn't help.
2. Issue goes away if the repeater connects to the main wifi instead of the guest wifi.
3. Issue reproduces with guest router in both repeater and media bridge modes.
4. Reverting to 386.2_6 makes everything work properly again.
Does anyone have a similar bridge to guest network setup? Appreciate any suggestions! :)
I've tried this with my own setup just now with 2x RT-AC68U routers on 386.3 (I haven't updated to 386.3_2 yet).
Primary router IP is 192.168.29.1, second router in repeater mode is set to get assigned an IP via DHCP, and gets assigned 192.168.29.76.
The Guest Network on my primary router is in Index 2 (so not on a separate VLAN like Index 1)
Maybe try a factory reset?
Out of curiosity, why do you connect the guest router as a repeater to the guest SSID instead of the primary SSID?
Have you tried connecting to the Guest router yourself?
I think you'll find that it makes no difference whether you connect the guest router to the primary or guest SSID - from my own testing, anything connected to the guest router has full access to the primary network (network shares, chromecasts, etc), regardless of which SSID the guest router connects to the primary router on.
The problem goes away if I connect the repeater router to the main wifi instead of the guest wifi. Thanks for the tip!
My main router is in AiMesh mode. That seems to be the difference in our setups. I tried again today and can still reproduce the original problem.
